-   -   What is the temperature of the water in a water to air AC unit? (http://www.diychatroom.com/f17/what-temperature-water-water-air-ac-unit-41643/)
abefroman 04-02-2009 10:24 AM
What typically is the temperature of the water in a water to air AC unit?
Do they still use freeon in those?
yuri 04-02-2009 10:33 AM
A chilled water coil runs in the 50 degF or less range and the cool water is produced by a chiller or refrigeration unit which nowadays uses the less ozone depleting refrigerants. Freon is a generic name invented by DuPont I believe.
abefroman 04-02-2009 11:08 AM
Thanks!
Is the chilled water more efficient or less expensive than a condenser type unit, or is a condernser all around better?
yuri 04-02-2009 11:10 AM
Not sure why you are asking. Chilled water is for multiple condos and large commercial/institutional jobs (hospitals etc) with one large over 50 ton unit. Efficiency has to do with the design of the machine.
abefroman 04-02-2009 11:14 AM
Just curious, there are some condos, that have an individual condenser for each unit on the roof from what I've been told.
yuri 04-02-2009 11:17 AM
FYI: Chillers:http://www.trane.com/Commercial/DNA/View.aspx?i=975
The units you see are probably your average freon split system with condensor on roof.
