What Temperature Should I Be Receiving From My Vents When It Is 100 Degrees Outside? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 10:56 PM   #31
Originally Posted by JJboy View Post
Delta 17 is good.
yup and is cooling just fine.
Will run same tests tomorrow during the day.
I normally only get 12-13 difference when it is hotter outside and in the attic.
Tomorrow will be the first time I check it right after the coil though.
blarose is offline   Reply With Quote
Old 07-23-2011, 10:58 PM   #32
An old Tradesmen
Rewards Points: 7,832
Originally Posted by blarose View Post
It was at the grill, but just went up and did it at the return duct and I am getting .5-1 degree warmer.
1 degree gain is kind of ok. On a system moving 1200 CFM, that would be just a little over 1200 BTUs gained.
Old 07-26-2011, 11:52 PM   #33
same issue around 18 degree split during the night and cool days, and 12 degree split on hot days.
Old 07-26-2011, 11:56 PM   #34
JJboy's Avatar
Time to clean coils and check SH and SC.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-27-2011, 12:00 AM   #35
Ok thanks.
Both coils are definitely clean.
Can you explain how I would check the SH and SC?
THanks
Old 07-27-2011, 12:08 AM   #36
JJboy's Avatar
Ok thanks.
THanks
At this point you need to call a tech to hook up the gauge and check the pressures and temperatures
Old 07-27-2011, 12:12 AM   #37
they were out here few days ago and he told me the following numbers
75 and 225
is there something else I needed?
Old 07-27-2011, 12:17 AM   #38
JJboy's Avatar
75 and 225
He gave you Suction line pressure 75PSIG and Liquid line pressure 225psig
He need to inform you SH and SC.....
Old 08-01-2011, 11:30 PM   #39
I am thinking my outside unit is running too hot.
It seems to be a good bit hotter than most others I have felt.
How would I check the amperage on the fan motor and compressor?
thanks
Old 08-01-2011, 11:57 PM   #40
I'm Your Huckleberry
Rewards Points: 2,270
Ok thanks.
THanks
http://contractingbusiness.com/resid.../cb_imp_17963/
Doc Holliday is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 12:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
