What T-stat To Use - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 10:45 PM   #1
What t-stat to use
I have a GMVC950905DXAB 95%, 2 stage, 90 K Btu gas. (It has comfortnet logic) a GSZ130421 heat pump ( no Comfortnet).
What T-stat would be easyist / best to install. my installer is not famillar (SP?) with this system.
Please help. Furnace is in running with old Honneywell T-stat and cycling every 5 min.
Thanks-P
PB Chumdog is offline   Reply With Quote
Old 12-09-2010, 03:11 AM   #2
incrae the antipator to run longer.
hvaclover is offline   Reply With Quote
Old 12-09-2010, 03:51 AM   #3
An old Tradesmen
Rewards Points: 6,914
The Honeywell IAQ thermostat (YTH9421) cal control your heat pump and both stages of your gas furnace.
The Following User Says Thank You to beenthere For This Useful Post:
PB Chumdog (12-09-2010)
Old 12-10-2010, 07:26 PM   #4
O/B terminal
Im programming my IAQ 9421C1010, step 0176. Dose the O/B terminal control heating or cooling?
If you have any other tips to share in the best set up for this T-stat I would like to here them.
Old 12-11-2010, 09:50 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
o controls cooling. it is put in the top left of the control panel in W1/O terminal
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
PB Chumdog (12-14-2010)
Old 12-12-2010, 07:04 AM   #6
An old Tradesmen
Connect the IAQ to be able to slow the blower in cooling mode if the in door humidity is high.
Old 12-18-2010, 08:23 AM   #7
Okay, the Heat pump is now wired in I've been using the gas furnace for heat.
(I set the cut off temp at 60* to get the furnace to run without calling for the HP.)
It has been cold here for the last 2 weeks, 10~25*
I reset the cut off to 15* to test the heat pump and get no responce from the heat pump. Ive got good voltages at the HP 28v on OR & R to BL. 240V @ contactor.
1) Is the HP locked out do to sitting for a week without power?
2) What should I check/change to get to it to run?
3) Should the TXV valve bulb be mounted inside the coil box or outside ?
(installer has it inside on suction tube. Instructions say outside at
4 or 8 o'clock position and insulate)
I can add wiring daigrams if needed.
Thanks in advance.
Old 12-18-2010, 12:15 PM   #8
An old Tradesmen
You shouldn't have voltage to or at the heat pump. And you need voltage to the Y at the heat pump.
T stat with 2 wires on 240? OffRoadAudio Electrical 6 12-13-2011 06:52 PM
Replacement Thermostat Problem! Confuserated HVAC 8 03-26-2010 08:17 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
Which Stat for New Carrier 58 MV Chemist1961 HVAC 10 12-21-2008 06:35 PM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 06:20 PM
