What Is This Switch Called? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 11:03 AM   #1
What is this switch called?
Just wondering what is the name of the safety switch that looks like a black eye mounted on the red jb cover mounted near the furnace/boiler called? Does it work off heat or does it actually melt out? Thanks.
Plumbvoltage is online now   Reply With Quote
Old 02-15-2009, 11:08 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Need to post a pic of it. It may be a heat detector and wired into the fire alarm panel if you have one. They are a warp switch I believe.
Old 02-15-2009, 11:19 AM   #3
I'll try to get a pic of it. Going out with the family for a little while will try this afternoon.
Old 02-15-2009, 08:33 PM   #4
Here is a pic of the switch. It says it is a thermal switch so I assume it breaks the contacts when it reaches a set temp.
Old 02-15-2009, 08:56 PM   #5
Hvac Pro
yuri's Avatar
Is this a single family residence? Do you have a fire panel? I have seen homes that had tenants and the fire code made them put a panel in with pull stations, heat detectors. When any of them activate it breaks the power to the furnace/boiler.
Old 02-15-2009, 09:04 PM   #6
This is a single family dwelling and there is no fire panel just one of these by the furnace/boiler the standard emerg switch at the top of the stairs and wired smokes and a few smoke/co detectors throughout.
Old 02-15-2009, 09:16 PM   #7
Hvac Pro
yuri's Avatar
Hang in there, we have some electricians on this site. If not you may want to get a local one to look at it. Red plate usually means fire panel/emergency device.
Old 02-15-2009, 09:24 PM   #8
I know it is an emergency device wired to the boiler. I am just wanting to know what is it called and wanted to know if it melts out and would need to be replaced if there ever was an issue. I know how it is wired in.
Old 02-15-2009, 09:45 PM   #9
Does it say Firetrol anywhere on it?
jerryh3 is offline   Reply With Quote
Old 02-15-2009, 09:54 PM   #10
No it doesn't. It does say Inner-Tite Corp
Old 02-16-2009, 09:54 PM   #11
I got it. It is a fusable link that melts out at 165 degrees. The center just pulls out and has a metal spring like contacts inside.
Old 02-16-2009, 10:52 PM   #12
Those are generically known in the trade as a Firomatic thermal switch.
In my area, they are used mainly with oil burners in conjunction with Firomatic thermal valves at both the fuel oil tank outlet and oil burner fuel unit inlet.
KayJay is offline   Reply With Quote
Old 02-16-2009, 11:03 PM   #13
Electrician
Its a thermal cut out, only required for oil fired appliances. Not an electrical code by the way.
chris75 is offline   Reply With Quote
Dimmer Switch Vandiyan Electrical 21 12-15-2008 08:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
