What Sort Of Duct Is This? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 12:53 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
What sort of duct is this?
My AC duct looks like this.
They are old and I don't know what is the material. An HVAC professional who inspected them advised for them to be replaced.
Anyone have any idea what this material is and should I go ahead and replace them with a newer materials?
picflight is offline   Reply With Quote
Old 08-26-2011, 01:02 PM   #2
Rewards Points: 6,652
Are you talking about the fiberglass wrapping, or what is under the fiberglass. What do they look like, when you go look at the main trunk in your attic? You do need more insulation up there, because it looks like only a inch, which is not going to do anything for helping to keep the home warm in the Winter, or cool in the Summer. There should be at least 8 inches min. up there. I would go around 12 inches.
Old 08-26-2011, 01:24 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Could be asbestoes, so be careful, avoid shredding it. If you replace, consider adding like 3 feet of extra insulation afterwards, you hardly have any. Having the ducts under the insulation will make the system much more efficient too.
Old 08-26-2011, 01:32 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
Thanks for the responses, and insulation is my next project to work on.
Old 08-26-2011, 02:29 PM   #5
fabrk8r
fabrk8r's Avatar
It looks like it may be what is known as "snaplock" pipe that has been wrapped with fiberglass. It's in good shape and should do a good job of supplying air. Are the returns in the floor?
It may be "spiral" pipe, but I doubt it since it is residential, unless the guy who owned the house at the time it was installed was a tinner.
As far as putting 3' of insulation in your attic, probably not necessary since you live in S.California, but it wouldn't hurt to add 12".
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-26-2011, 02:52 PM   #6
Busy DIYer
picflight's Avatar
Rewards Points: 150
[SNIP]
Returns are in the wall, the top just under the roof line, the vent which puts the air in the rooms, if that is what you mean by returns.
The large grill, Intake is on the bottom, near the living room.
Old 08-26-2011, 02:58 PM   #7
fabrk8r
fabrk8r's Avatar
The pipes in your attic are supplies (supply air).
The large grill is the "return air grill". It returns the air to the furnace/air handler.
The only reason I asked is because I just wanted to make sure there was a return because I didn't see any R/A duct in the attic.
Old 08-26-2011, 02:59 PM   #8
Those pipes are supply, your return is that grill you said that is near the living room.
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 07:25 PM
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 12:45 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
