What Size Wire And Breaker Needed? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 09:49 AM   #1
What size wire and breaker needed?
I have a Bryant/Carrier electric furnace (model FA4CNF024) that I would like to install. The old one used a 125 amp breaker and a really big wire (not sure of gauge). What I need to know is what size wire and breaker should I be using. Can I use the 10/3 wire I have on hand? Thanks
stlouistruckn1 is offline   Reply With Quote
Old 02-06-2012, 10:13 AM   #2
HVAC Tech/ Browns Fan
On the indoor unit will tell you what kind of amp breaker to use.
Tator1076 is offline   Reply With Quote
Old 02-06-2012, 10:58 AM   #3
Rewards Points: 314
the National Electrical Code is your friend.
There are many things that you have to take into consideration for electrical wiring. like;
isulation type
wire type
wire gauge
conduit fill ratio
proper termination of conductors
electical service size
etc. etc.etc.
Do yourself a huge favor, call a master electrican.
Then get a permit.
your insurance may be void by diy.
be safe!!!!
bobinphx is offline   Reply With Quote
The Following User Says Thank You to bobinphx For This Useful Post:
Tator1076 (02-06-2012)
Old 02-06-2012, 03:35 PM   #4
An old Tradesmen
Rewards Points: 7,306
What size strip heater package does it have in it? Sounds like the old one had a 20 or 25KW package in it.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (02-06-2012)
Old 02-06-2012, 09:35 PM   #5
Will have to look at the pack when I get back home... The wire going to this unit is currently about a 2 ga I would guess (the wire itself is about a1/4 inch thick). The sheath is gray in color like maybe underground wire (I guess). There is a black wire a red wire and a ground wire in it (yet it is 220?).
My problem is that I need to re-wire it because I need to move the furnace and where is it going the wire is too short. Just thought if I new what wire to use on it I could pull a new one and hook it up like what is there, with no problems. Thanks
wire size vs breaker size Jimster 481 Electrical 3 08-20-2011 09:41 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
