What Size Are Return Ducts Usually - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 04:50 PM   #31
K.M.G's Avatar
Rewards Points: 119
So Do I fill this hole in??? or at-least one side, or should I try and get a "Real Duct" installed and possible convert everything
I just don't know???
My new sub floor needs to be installed and have this hole there, and need to know do i close it up.
If I don't close it up,Can I drywall right to the floor as this hole and no drywall was hidden with the old vanity.
K.M.G is offline   Reply With Quote
Old 09-26-2009, 04:52 PM   #32
An old Tradesmen
Rewards Points: 7,332
Drywall over it.
And cut another hole in the opposite wall, and put a return grille on it. So you don't loose any return.
Old 09-26-2009, 06:18 PM   #33
K.M.G's Avatar
Rewards Points: 119
Originally Posted by beenthere View Post
Drywall over it.
That's the thing,the wall right behind it is the Hallway and It has a Grill
That's why I was asking if I should cover up the hole in the floor/drywall the wall,but now with all this info I've found out about my Heating system I have now I'm .
Or do I just drywall and leave the hole as it's apart of my Heating system it seems.
Don't know if loosing one hole will be a problem
Old 09-26-2009, 07:08 PM   #34
An old Tradesmen
You don't want a return in a bathroom.
Loosing one return can be a problem that bites you hard down the road.
Doesn't matter if there is already a return in the hallway. Another one won't hurt your hallway.
a/c return size bmancanfly HVAC 2 09-03-2009 07:16 PM
Return air ducts sejab HVAC 7 01-16-2009 10:47 PM
Help with return and supply size XHornet85 HVAC 9 09-16-2008 11:13 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 10:00 PM
