09-22-2009, 08:14 AM
#16
What Size are Return Ducts Usually
You all hit the nail on the head.
At HVAC-Talk I've seen so many threads closed or edited because they don't allow pricing because it is NOT a DIY site. Then I see you post a comment indicating this site does not allow pricing becaue it IS a DIY site....
I assumed (incorrectly) that you were joking because many of us are members of that other site also.
Now that I know you were serious....it is even funnier if it is true
Talk about irony...
Key1
In the land of the blind....the man with one eye is king....
09-22-2009, 08:28 AM
#17
Ok I had my laugh...I guess I should try and contribute to the discussion.
To the OP (original poster),
I recomend you perform or have performed an ESP (external static pressure) test first since it sounds like you plan to make your system more restrictive. At least you will know where you stand and what you have to work with. If I were operating blind, I would make the supply duct work as large as possible and add dampers so I could make adjustments as needed. For return duct, I would also make it large and able to accomodate a large low restriction 5 inch media filter.
What size is your AC (in tons) and your coil (in tons) and your furnace (in btu's)? Where are you located?
Key1
09-22-2009, 09:07 AM
#18
Moderator
Funny as they may be to you key1cc, the pricing discussions are not welcome on this site. That's the decision of site administration and the mods therefore do not permit it. Discussions of what a contractor would charge to do work have no place on a site for DIYers, or at least this site.
Glad I could give you a good chuckle though.
09-22-2009, 10:05 AM
#19
No offense KC.  The rule itself is not funny it's just the irony of the DIY site and the non-DIY site having the same rule on pricing...
Key1
09-22-2009, 04:24 PM
#20
Moderator
Hey at least we're consistent!
09-22-2009, 05:23 PM
#21
An old Tradesmen
ROFL
09-23-2009, 12:37 PM
#22
I don't see anything wrong with telling someone how much something should cost.
As if it's going to cost less to get a Pro in then you go and buy everything
09-23-2009, 12:41 PM
#23
Key1
How Would I be making the system more Restrictive???
Would I not be making it more Effective
Since now the Furnace has a Direct line to return the air instead of guessing
Would the Joist have to be cut to get the new line in
This is what I found when I removed the Vanity a hole in the floor and she this wall divides the Bathroom and hall way.
09-23-2009, 01:19 PM
#24
An old Tradesmen
There is no set, "it should cost".
Thats like saying your hourly wage should be $9.50 an hour to work asphalt, weather you live in Maui Hawaii or Smallville.
09-23-2009, 09:35 PM
#25
Would I not be making it more Effective ....
Your first sentence in your first post you stated that you do not have any return ducts in your home. Yet if your system is operating you must be getting return air from somewhere. Maybe from the area the furnace is located in. We may be able to tell you more i f you post pics of your furnace set up. Let's assume for a second you are correct and you have no return ducts and your blower is simply pulling air from it's current location....then you add ducts and force that return air to travel though the return ducts around corners and up walls....you have just made the blower work harder to pull the same amount of air because now it has to overcome the resistance of the ductwork. Typically this is not a problem if the ducts are large enough to accomodate your airflow needs and your equipments airflow capability. Infact systems are designed this way (with returns throughout the house) because it helps to equalize temperature throughout the house...and yes if would be more "effective" as long as your static pressure is within specifications.
Key1
09-23-2009, 09:48 PM
#26
I lived In Smallville until I moved to a great metropolitan area and assumed the identity of a mild mannered hvac tech who.. ah crap...my meds are wearing off again
Just slow, not stupid.
09-24-2009, 06:07 AM
#27
An old Tradesmen
LOL...
09-24-2009, 09:08 AM
#28
LOL...
09-26-2009, 04:53 PM
#29
09-26-2009, 05:02 PM
#30
An old Tradesmen
You have panned joist. A common method.
You a return trunk. And the joist are panned back to it for the returns.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
