What Size A/C??? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 05:51 PM   #1
What Size A/C???
I have a levitt cape about 600 sq feet to cool but in the cooling area is a kitchen and boiler in the wall. My house gets a lot of sun. In the daytime. I had a 12,000 btu last year and it did nothing. Any idea what size would be ideal, I've heard too much is not good?
Ckb3216 is offline   Reply With Quote
Old 05-18-2013, 06:02 PM   #2
Rewards Points: 156
Can you do something to reduce the solar gain? Plant a tree or get some shading screens or an awning?
strategery is offline   Reply With Quote
Old 05-18-2013, 06:04 PM   #3
No I can not
Old 05-18-2013, 06:08 PM   #4
Rewards Points: 156
I would look into a ductless minisplit or something. You don't have ductwork so a heat pump or ac isn't going to do any good. Portable ac's aren't all that good imo
Old 05-18-2013, 06:19 PM   #5
What is the reason that a larger a/c wouldn't do
Old 05-18-2013, 06:30 PM   #6
Rewards Points: 156
I suppose it could but a bigger one will probably need a duct system. Bigger than 12k is 1.5 ton territory. You don't have ductwork right?
Old 05-18-2013, 06:32 PM   #7
No ductwork
Old 05-18-2013, 07:27 PM   #8
Rewards Points: 156
Why not look into a 16-20k ductless split? If you had ductwork, if say look into a 1.5 ton heat pump or ac.
I would also consider some energy improvements first if possible.
Old 05-19-2013, 05:16 AM   #9
An old Tradesmen
Rewards Points: 7,370
An 18,000, or larger window unit could be used.
http://www.nextag.com/18000-btu-wind...r/stores-html#!
http://www.walmart.com/ip/General-El...W24DQ/20449875
The Following User Says Thank You to beenthere For This Useful Post:
tylernt (05-20-2013)
Old 05-20-2013, 01:41 PM   #10
Special User
Rewards Points: 1,230
Too large of an A/C will run in short bursts, and fail to remove humidity. But if there's a large heat load, then a large A/C will run for a long time so it will remove humidity, no problem.
I wouldn't hesitate to put in a 18,000BTU window unit if the 12,000 didn't have the muscle to do the job. But, be aware that you may need a 240V outlet to plug it in to!
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-20-2013, 02:47 PM   #11
Ok yeah I'm gonna go with the larger btu unit (18,000 +) I'm having electrician run a home run for the a/c, hope it works out and I keep cool is summer
Old 05-20-2013, 03:06 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
As much as I avoid them an extended warranty may be a good idea with these units as they are all made in China and put it this way the quality is "not overbuilt" in them. They are made to throw away. Try not to run it when there is lightning either or a power surge could damage it.
Old 05-20-2013, 03:08 PM   #13
Thanks for the heads up. My wife and I were originally going to do the split duct but that's way out of our price range. So I'm going to have to go with an a/c unit.
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 11:20 AM
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 01:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
