What Size AC? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 04:41 PM   #1
Lightbulb
What size AC?
House is a 1971 concrete block ranch, 1480 sq ft, double attached garaage (not conditioned) 5 windows facing S.W. (3 are small-bath & bedrooms). Attic sealed and insulated recently to R31. Attic has original (1971) rectangular sheet metal ducts (internally insulated).
Original oil fired furnace works but I never use it. (Live in hot humid Tampa, FL) My intent is to replace with A/C and Electric heat (rarely use) or heat pump W/ strips. Gas is not in the area. Temp here gets up around 92 (now) and rarely gets down below 40 in Jan (only a day or 2 at a time as a cold front passes through) Heat pump heat operation is not a big consideration here. Present A/C condensor is 19yrs old. Air handler is original (38 yrs old)
Contractors have tried to sell me up to 4 Ton units. Originally came with a no Seer 2 1/2 Ton Chrysler temp.
My question: Can i get a 2 1/2 T to work again with the attic insulation improvements (R31), tinted glass, window awnings on SW windows, sealed up attic holes, garage attic access blocked off, new light colored roof w/ ridge vents? Or am I wasting my money trying to get a 2 1/2T to work? House is going to be a rental but I don`t want tennants moving out because of being uncomfortable in the summer. House has 200A box.
What suggestions have you?
mikgills is offline   Reply With Quote
Old 10-03-2009, 03:46 PM   #2
Registered User
Rewards Points: 4,924
Welcome to this site, I hope someone answered you!
Be safe, Gary
Old 10-04-2009, 12:38 AM   #3
Remodeler
MinConst's Avatar
A rule of thumb is 1 ton does 500 sq' of well insulated space with good doors and windows. So your 2.5 ton unit should suffice.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 11:33 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 05:42 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
