What Should The High Side Be? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 11:23 AM   #1
what should the high side be?
Hey when looking at the pt chart, what do you look at to see what the high side should be?
Do you look up the outside temp and convert that? Do you look up the inside temp, sustion line temp, superheat, what?
I know how to do superheat and wet bulb all that stuff but nothing with the high side.
moses is offline   Reply With Quote
Old 08-01-2011, 11:31 AM   #2
JJboy's Avatar
Superheat - Suction line
Subcooling - Liquid line
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-01-2011, 12:18 PM   #3
for example say it is 90 degrees outside. suction line is say 80 PSI, webulb is 65, inside air is 75, I have not done the math but say the superheat is 20. what should the high side be and how did you get that?
When I look up 90 ( for out side air) on the PT chart is converts to 168.4. way to low for high side PSI. Or is the PT chart not for high side readings? and if not how do I know what it should be?
Thanks again for all the help!
Old 08-01-2011, 12:30 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
that reading is for what the pressure in a freon bottle would be or an idle system. High pressure depends on the outdoor temp and how clean the condensor coil is. If dirty the pressure goes up. In the old days of 8 SEER units I used to add 20 deg to say 110 F and convert that to a pressure. 20-30 was norm and above that the coil was dirty or air in the system. The newer 10 SEER and over will run lower head pressure as the condensor coils are much larger so there is NO rule of thumb for pressures of any kind anymore on either side of the system. Really have to use the manufacturers subcool or superheat chart that comes with the condensor to know what to do or have more than 10 yrs experience to know what is normal.
Old 08-01-2011, 01:08 PM   #5
where did you get the 110 F from is that the outside temp at that time?
Old 08-01-2011, 01:17 PM   #6
Hvac Pro
yuri's Avatar
your example of 90 degF OAT plus 20-30 degF then convert to pressure from the chart.
Old 08-01-2011, 03:08 PM   #7
ok yup I got ya
Thanks for the help!
high low side wetbar HVAC 2 06-01-2011 07:36 AM
Anyone ever heard of a meter on the high voltage side? viper Electrical 9 05-20-2011 12:41 PM
High Efficiency Side Exhaust Vent TerrySki HVAC 8 04-06-2010 03:55 PM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 10:17 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 01:48 PM
