What Should Boiler Temp Be? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 07:14 AM   #1
What should boiler temp be?
Been having a few issues on constant hot water and of 1 day ago we've had plenty for some unknown reason. But I did notice my gauge on the front of the furnace reads about 235 degrees. I have the aquastat set at 160 low and 180 high. What should the gauge read? I believe it works as when the hot water is run the gauige goes down.
Bearcamp is offline   Reply With Quote
Old 01-17-2009, 10:41 AM   #2
An old Tradesmen
Rewards Points: 6,598
Shouldn't rise more then 20 above the high limit temp.
Old 01-17-2009, 12:13 PM   #3
Dr Heat's Avatar
is this a boiler, water heater or furnace?
If it is a boiler 235 is steam and a hot water boiler system will not heat with steam. As to the aqua stat if the boiler temp is 235 and the stat is set at 180 it is not working.
Dr Heat is offline   Reply With Quote
Old 01-17-2009, 04:22 PM   #4
An old Tradesmen
If his guage is accurate for temp.
If he looks, I bet his pressure is above 22PSIG.
So its not steam at 235F if his pressure is above 22PSIG.
But, his aquastat is probably defect if its rising 55 above set temp.
Old 01-17-2009, 05:17 PM   #5
Journeyman
Agree; I have had a hot water boiler up to 240F(in a closed loop sytem)long story. Don't recomend that high of a temp for residential, get your aquastat checked.
pipefitter636 is offline   Reply With Quote
Old 01-18-2009, 08:42 AM   #6
tk03's Avatar
Rewards Points: 150
Take a temperature reading on the hot supply water pipe coming out of the boiler to verify actual temperature.
tk03 is offline   Reply With Quote
Old 01-18-2009, 04:06 PM   #7
Dr Heat's Avatar
Been you are correct that's why I like this forum, in the field it is easier to pickup on those things. Now that I have to coach techs over the phone I need to hone my analytical skills.
Old 01-19-2009, 08:04 AM   #8
An old Tradesmen
Doing diagnostics over the phone while trying to write up proposals, do accounting, and set up jobs is always a PITA.
Its a real pain, when you get answers back like, the gas pressure is good.
And then you say, how much was it, and they say, I forget.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 10:01 AM
Boiler questions mudpaws HVAC 4 06-11-2009 09:22 AM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 09:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
