What To Seal Ducts With In Unconditioned Space - Foil Tape? Mastic? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 01:56 AM   #1
Rewards Points: 156
What to seal ducts with in unconditioned space - foil tape? mastic?
If you have ducts running through your basement or attic what do you think is better at sealing them? Is one easier or more effective than the other? Mastic would just be painted on the duct seams with a brush correct?
strategery is offline   Reply With Quote
Old 12-19-2011, 04:22 AM   #2
An old Tradesmen
Rewards Points: 6,876
Mastic brush applied, or mastic tape.
Old 12-19-2011, 10:21 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now what do you think would be advisable?
No really...which do you think would be the answer?
1. Foil tape? (made for just this purpose and not effected by heat)
2. Paint on mastic? (made for what application)
If you were to name some products this would go a lot better for you.
XXX
Old 12-19-2011, 10:30 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Carlisle Hardcast foil tape.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Bud Cline (12-19-2011)
Old 12-19-2011, 03:59 PM   #5
An old Tradesmen
Not all UL181 foil tape is actually good for sealing.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Best tape and sealant for 6 mil plastic sheeting in crawl space... nadsab Insulation 6 04-29-2011 11:18 PM
Seal Space Between Furnace and Flue Exit? 99altrade HVAC 6 12-21-2010 05:59 PM
Seal Space Between Gas Furnace Flue and Furnace? 99altrade Plumbing 0 12-21-2010 10:37 AM
Individual conductors in unconditioned space gp_wa Electrical 3 12-07-2008 05:24 PM
