What Requires Electricity? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 07:22 AM   #1
Rewards Points: 270
What requires electricity?
Hello all,
I have a general question... during the recent power outage in NJ, my sisters steam heat system did not work. Her thermostat is battery powered. What part of this system would generally require electricity. Is it the ignition/modulation for the burner?
How much electricity would it take to keep this system going (is it very little?).
Assuming there is no pump, or fan connected to a steam system, it would seem that it wouldn't take much electricity to back this system up (?)
pcampbell is offline   Reply With Quote
Old 11-05-2011, 09:42 AM   #2
raylo32's Avatar
Rewards Points: 1,226
Without more info you'd have to tell us. Could have pilot or electronic ignitor. Could have cirulation pumps. A quick look at the system including any label plates should answer your questions.
raylo32 is online now   Reply With Quote
Old 11-05-2011, 10:02 AM   #3
An old Tradesmen
Rewards Points: 6,112
Basic residential steam system can be ran on a small generator. Gas or oil burner will require less then 1KW.
Old 11-05-2011, 12:39 PM   #4
If there are no circulation or fuel pumps then you might be able to switch over to a standing pilot system using a thermopile and millivolt gas valve. The thermopile will generate the electricity needed to open the gas valve. A professional will need to asses the system to see if this is possible.
Master of Cold is offline   Reply With Quote
Installing an electricity monitor sensor inside my fuse box - which wire? nickday Electrical 5 04-17-2011 02:10 AM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 04:23 PM
electricity from house to garage J MAC Electrical 19 07-05-2009 07:19 PM
Is there a way to tell what's using the electricity from panel? Piedmont Electrical 9 02-12-2009 01:04 AM
Old A/C use more electricity than old A/C? clue89 Electrical 4 03-02-2007 05:47 AM
