What Relay Points Are Typically Needed For A Central Air Install? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 02:25 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
What relay points are typically needed for a central air install?
I have a custom thermostat system I made myself years back, and I plan on getting central air. The board I use has a relay that is already designated for the AC, along with furnace, and fan. There's a spare relay as well if I need it. Will I need anything else for AC to work? Currently the AC wire just goes to the furnace and ends there unconnected. The relay closes it with the red. Is that sufficient for a tech to be able to install central air? I imagine he just has to extend those wires to the outside unit relay? Currently my system will also run the fan when in AC mode, but I can easily reprogram that if needed.
This is the controller:
Currently, red to white = furnace
red to green = fan
red to yellow = AC?
Does this look right? I want the tech to be able to hookup whatever wires would normally be standard and it working flawlessly as is and if I need to do any chances then I'll do them now.
Old 03-30-2013, 05:39 AM   #2
An old Tradesmen
Rewards Points: 6,086
Yep, just need it to close R to Y and R to G when it calls for A/C.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-30-2013)
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
no ductwork needed to install a wall fan ? amakarevic Plumbing 2 01-22-2010 06:23 PM
New Here and help needed with multiple flourescent install TIAG02M3 Electrical 4 11-26-2009 09:26 PM
How to install central air and sub-panel Stubbie Electrical 32 01-16-2009 09:06 AM
Help needed with finding the wires to install a range hood triginpgh Electrical 6 01-10-2009 03:09 PM
