What Is Proper Temp. Of Supply Air - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2006, 07:15 PM   #1
What is proper temp. of supply air
South Florida. 90 degrees outside. 5 ton split unit.
I get 58 degrees at a register near the air handler. 64 degrees in a back bedroom.
What should/can it be?
bob-smith is offline   Reply With Quote
Old 07-12-2006, 07:18 PM   #2
are the a/c ducts insulated?
redline is offline   Reply With Quote
Old 07-12-2006, 07:32 PM   #3
yes they are insulated
The coil ( inside the air handler) is about 5 years old. The previous owner didn't maintain it. I thinking of replacing it. I trying to judge current performance.
I have a new 10 seer condenser unit. Pressures are good. Lots of water out the drain. Just trying to get the most out of the system.
Old 10-18-2006, 05:59 PM   #4
Thoroughbred Mopar Man
Rewards Points: 502
Hi bob-smith
It sounds to me like you have an air flow problem. This is pretty easy to figure out. Use a digital thermometer. Take a temp reading at the return air grill, then take one at the closest supply register to the furnace. Subtract the two temps from each other. If you have less than 16deg and more than 22deg difference. You will need to have the blower speed set. If you have a good HVAC company, they will be able to calculate and set this for you.
Good luck, let me know if I can help you in the future
Rusty
#CARRIERMAN is offline   Reply With Quote
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 06:47 AM
Running Supply to Attic cibula11 HVAC 2 02-06-2007 06:08 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 07:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
