What Is With The Price Of 134 A - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 07:31 PM   #1
What is with the price of 134 A
I was wondering if any of you know why 134A price has basically doubled over last year. I use this in my old ford truck. I had it converted from R12, a few years ago. But there is a small leak somewhere in the system that my mechanic just can't find. Even when we have inserted dyes.
And we tried a can with a leak stop in it. But it did not help.
Anyway I loos about one can a year. Last year I could get a can for $5.00 or less. Now your lucky to find it under $10.00.
Just wondering if it is due to increased demand. Higher profits. Or has the government taxed it, like they did to R12?
tom1336 is offline   Reply With Quote
Old 07-19-2012, 07:52 PM   #2
Rewards Points: 582
if you need it you pay for it right..... they have us over the barrell.....ceo's linning there pockets just my thought.....
Old 07-20-2012, 04:52 AM   #3
An old Tradesmen
Rewards Points: 7,376
They're preparing for the phase out of R134A.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-20-2012)
Old 07-20-2012, 05:00 AM   #4
Any info on the compatibility with the systems using 134A. Will you be able to just suck out the 134A and charge with the new stuff or will you have to retro fit... if you even can.
Like myself i know a lot of folks that have older cars that took R12, and when their AC needed a recharge or top off, due to the expense of R12, converted to 134A. And I mean converted, not just a valve change and evac and recharge.
And we don't want to get rid of our great old cars/trucks. We like they way they look and so on.
Old 07-20-2012, 05:08 AM   #5
An old Tradesmen
They haven't decided on another refrigerant yet.
Old 07-20-2012, 05:26 AM   #6
Sounds like "our' government at work! I know we took at away from you, but we are working on something we will give you?????? And it may or may not work.
Old 07-20-2012, 05:31 AM   #7
An old Tradesmen
When R134A came out, it was only a "short term" refrigerant.
Old 07-20-2012, 12:25 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Tell him to check the mechanical connections on the lines and dryer to make sure theyre tight,also check shrader valves.
Your hoses might also be an issue depending on age,I seem to remember being an issue when 134 came out about size of molecules allowing it to leak through some hoses.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-21-2012, 09:01 AM   #9
Rewards Points: 236
its probably the evaporator. its pretty hard to get a good look at em. and checking the drain doesn't always tell.
Fix'n it is offline   Reply With Quote
Old 07-21-2012, 04:22 PM   #10
He has tried with dyes and even with one of those "sniffers. We just nave not found it. But I loose about one can a year. So you know it is a small leak. And it my only leak under certain situation, like when he engine torques just right. But in looking he has pulled this, jiggled that, and so on.
Just found out that a place called Rural King has 134 in sale 4.99 per can, or 119.99 for 30lbs. Darn nice price. Today is last day of sale.
Old 07-21-2012, 07:26 PM   #11
MarginallyQualified
Rewards Points: 2,464
Ammonia might get it done.
Old 07-21-2012, 11:03 PM   #12
As I recall that was used at one time. But it killed folks.. If I am recalling history correctly.
Old 07-21-2012, 11:51 PM   #13
An old Tradesmen
Its still used today.
Old 07-23-2012, 04:12 AM   #14
Check the compressor seal closely. It may be leaking when in use and stops when the system is turned off. I have a 88 chevy pickup that does this.
dtnel is offline   Reply With Quote
