What Is The Name For... - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 02:59 PM   #1
What is the name for...
I am looking to find the sticky, gummy, thick, black "tape" that is typically used to seal the small openings around the lineset penetrations through the plenum to the coil and is also used as a wrappable insulation for linesets. It is difficult to find if you do not know the name. Is there a trade name for this? Anyone?
civiltoatee is offline   Reply With Quote
Old 03-29-2011, 03:17 PM   #2
newtech's Avatar
Rewards Points: 164
Cork Tape
newtech is offline   Reply With Quote
Old 03-29-2011, 03:21 PM   #3
That looks like the stuff. So it is called "Cork Tape", but it is not made out of cork?
Old 03-29-2011, 03:22 PM   #4
HVAC / Plumbing
Armorflex ?
kenmac is offline   Reply With Quote
Old 03-29-2011, 04:01 PM   #5
HVAC Tech/Owner
Rewards Points: 604
foam insulating tape
Technow is offline   Reply With Quote
Old 03-29-2011, 04:10 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, cork tape is made out of cork.
Old 03-29-2011, 05:16 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 92
If you are looking to seal plenum holes my preferences are:
#1 silver foil duct tape
#2 silicone
#3 mastic or red durodyne duct sealer available for Pros
We also have access to black Virginia foam insulation tape which is what I use to patch small holes in AC insulation and wrap around TX valve bodies so they don't sweat and drip all over the furnace. Available only from refrigeration wholesalers. Try Acklands or Graingers, they may sell it to DIYers.
Old 03-29-2011, 06:41 PM   #8
fabrk8r
fabrk8r's Avatar
Thumb Gum...it's gray, not black, but it's great for sealing holes.
The cork/tar tape is messy, but it's better for line sets.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 03-29-2011, 06:46 PM   #9
Cork tape is the name. Sticky when it's new but after a few years it will no longer seal. Thumb gum or silicone lasts a lot longer.
Old 03-29-2011, 06:48 PM   #10
Thanks to everyone for all of the information and suggestions.
Old 03-29-2011, 07:09 PM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 92
Thumb gum in my experience always dries out and falls out unless you take your thumb and redo it once in awhile. Some of them liquefy from the heat of the bonnet and fall apart also. We use silicone 99% of the time now.
