Old 11-16-2008, 01:03 PM   #1
What is more efficient?
Hi-
Our house has gas heat. Last week I was in the attic, and found a fake fireplace that is electric. It says 120V/60Hz/1500W on the back, runs a fan out of the bottom, and has a thermostat. It's just my wife and I in the house, and she was asking if it would save us money to turn down the heat and just use the electric fireplace. The top has controls for fan, thermostat, and two switches that you can turn on and off that say 750 Watts.
Someone suggested using an electric blanket at night. Night time sleeping temperature is not the problem, it's during the day or evening that we mainly need the heat.
A couple of questions:
1. would this thing end up costing us more to run than relying on our gas? Our house is two story, the upstairs only has a master bedroom. We typically program our heat to run anywhere from 65 (at night) to 69 during the day. We live in Charlotte, NC.
2. Last night I had it plugged into an outlet that also has our TV/home entertainment system. We had all of them going at once, and it blew a fuse. I'm assuming I need to try another outlet?
I would appreciate any help!
Thanks, Brent
bsmith6356 is offline   Reply With Quote
Old 11-16-2008, 02:32 PM   #2
Electricity is way more efficient than gas. All the heat is left in the house and none is vented outside like gas.
The question should be what costs less for the same results. With gas prices increasing it is becoming a toss up.
750 watts is nothing and would have a hard time keeping a small bathroom warm. Running this heater for an hour will produce about 2500 btu's which is not much.
If you went with electric you would need a much bigger heater.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-16-2008, 06:24 PM   #3
An old Tradesmen
That heater on high(1500 watts) is barely enough for the average living room.
Old 11-16-2008, 07:12 PM   #4
i havent paid a gas bill in a while so i dont know rates but id be suprized if my gas bill for a month would be higher than my elec bill if i was using straight elec heat (non heat pump) i know it never used to be like that
kennzz05 is offline   Reply With Quote
Old 11-16-2008, 11:23 PM   #5
An old Tradesmen
Depend where you are.
Some places have very high electric rates.
Some areas in this country are 25 cents a KWH.
Old 11-17-2008, 12:01 AM   #6
I feel good with my 6 cents per KWH. Co-op.
Old 11-17-2008, 06:11 AM   #7
An old Tradesmen
Currnetly 10 5 cents here.
Goes up 30 to 40% in 2010 though.
Old 11-18-2008, 10:32 PM   #8
tk03's Avatar
The unit at 1500 watts is about 5000 btu's. With the fan it may work OK dependent on windows, room size, insulation etc.
tk03 is offline   Reply With Quote
Old 11-18-2008, 11:34 PM   #9
hvaclover's Avatar
No buddy pick up on the fuse blowing? Only the TV going.
Does the OP know what the home's electrical system is like?
Is the electrical panel too small for the family's power consumption?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-19-2008, 02:37 AM   #10
An old Tradesmen
Entertainment centers can have a high amp draw themselves.
So a breaker tripping with the addition of a 12.5 amp draw(6.75 if it was set to 750 watts) is not surprising.
Old 11-19-2008, 10:07 AM   #11
hvaclover's Avatar
Whadda'yamean?? My console B&W 12" Philco TV and '78 speed Victrola only draws 2 amps!
Old 11-19-2008, 10:09 AM   #12
hvaclover's Avatar
[quote=hvaclover;187212]Whadda'yamean?? My console B&W 12" Philco TV and '78 speed Victrola only draws 2 amps! j/k . This one was my bad. Iam not up on what all the entertainment devices do amp wise.
Old 11-19-2008, 10:08 PM   #13
An old Tradesmen
15 amp circuits are good for an electric heater plus anther appliance that draws more then 3 amps.
Stupid question about energy efficient light fixtures farmerde Electrical 16 11-16-2008 10:26 PM
energy efficient hood vent kjlorensen@arvig.net HVAC 2 10-11-2008 10:27 AM
Most Energy Efficient windows jogr Building & Construction 1 09-06-2008 02:00 PM
Energy efficient new home? kcrossley2 Building & Construction 10 01-27-2007 10:04 PM
