What Material Is Best To Fix The Leak In The Pipe Joints? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 12:40 AM   #1
What material is best to fix the leak in the pipe joints?
Hi! My furnace exhaust pipe has a small leakage in the pipe joints in my attic when raining. See the picture http://i599.photobucket.com/albums/t...wshot/Duct.jpg . What material is best to fix the leak in the pipe joints?
compiler is offline   Reply With Quote
Old 02-13-2013, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
We need a picture of the roof connection and the cap on the flue up in the roof---
water should not be inside of that flue----don't kill your self on a ladder---take the picture from the ground-----
Old 02-13-2013, 07:24 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I had a problem similar, turned out to be condensation from the warm pipe and cold air. I used a muffler sealer, it worked. There are several new products that will seal that. There is a high heat resistant silicone that you can get at an automotive store that would work great.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-13-2013, 11:04 AM   #4
Thanks for the info, BigJim. I will check the muffler sealer in the Auto Zone. By the way, I read the Epoxy is best to fix the leaking pipes at joints. Has anyone tried it? In addition, oh'mike, is the furnace exhaust pipe supposed no ANY water inside of the pipe at the time of raining? I think the wind-driven rain or condensation may cause a little water inside of the furnace exhaust pipe that goes through the roof. Is it not possible? See the outside picture of the vent at http://i599.photobucket.com/albums/t...t/IMG_0039.jpg
Tags
pipe leak in the joints
Leak at toilet feed pipe dunixi Plumbing 5 01-28-2012 07:08 PM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 10:06 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
How does this pipe work, and how do I stop the leak? jamolei Plumbing 10 12-20-2009 07:45 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
