What Are The Major Benefits Of Insulating The Refridgerant Pipes - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 09:21 PM   #1
Rewards Points: 278
What are the major benefits of insulating the refridgerant pipes
In my situation, it would be *linesets* of the refrigerant pipes for ductless splitless units.
Installer used the good stuff...rolls of tubing with insulation already on it. My electrician told me alot of HVAC guys use regular copper, then slowly put the Armourcell on it, etc.
Long story short, there is some areas in which insulation is not up to par...
What is the primary reasoning's for insulation, just short of keeping the refrigerant as cool as possible (no cool/heat loss) and condensation ?
The areas in my install in which insulation is short or need *better work*
- the last 8 inches or so where the linesets go into the condensers. I would have expected insulation all the way up to to the last 4 inches or so where they make the flared connection.
- I have quite some vertical runs. Where they brazed the linesets to the linesets coming to the air handler, they cut back around 12" of insulation to make the brazed connection. Only 1 or 2 of these dual linesets I have issues with. On the others, where I pointed it out, he wrapped the exposed copper with armorcell. In the 2 areas in which another worker was doing it, I pointed it out and he just wrapped it in 1 layer with the *foam insulating tape*, that was like 4 inches wide similar to a mastic tape roll but it was the foamy stuff but the overall thickness is thin
mobiledynamics is offline   Reply With Quote
Old 08-02-2010, 10:34 PM   #2
An old Tradesmen
Rewards Points: 6,944
On the large line. It just prevents it from sweating. It helps a bit more on the small line on mini splits. So the liquid doesn't flash to vapor to quick.
Old 08-03-2010, 09:50 AM   #3
Rewards Points: 292
Why is this (flashing) NOT a problem with regular split units?
V
veesubotee is offline   Reply With Quote
Old 08-03-2010, 11:05 AM   #4
An old Tradesmen
Regular split unit, has its metering device at the evap.
Mini split has its metering device in the outdoor unit. So its small line is not a true liquid line. But is more of a distributor line. And is not under as high of a pressure as a regular split is, so it can flash much quicker.
insulating pex pipes ibs325 Plumbing 28 03-29-2012 03:59 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
worth insulating pipes? wombosi HVAC 4 02-15-2009 06:32 PM
Insulating water pipes? CooperChloe Building & Construction 4 02-04-2009 11:11 AM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 09:14 PM
