What Is Ideal Low Side Suction And High Side Pressure? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 05:02 PM   #1
Rewards Points: 74
What is ideal low side suction and high side pressure?
Hello,
What is ideal low side suction and high side pressure? My unit is 2.5ton, r22 refrigerant. Thanks
shovad is offline   Reply With Quote
Old 04-16-2013, 06:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,440
there is none. pressures vary according to the house and outdoor temp and load on the machine and SEER rating
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (04-17-2013), shovad (04-16-2013)
Old 04-16-2013, 10:26 PM   #3
Rewards Points: 582
those would be the ones that cool the house well with the changing outdoor temps through out the day and night ben sr
Old 04-17-2013, 06:50 AM   #4
Rewards Points: 1,216
Pressures are changing all the time depending on the load, ambient temperatures, cleanliness of the unit, etc, etc, etc.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 04-17-2013, 09:26 AM   #5
Rewards Points: 89
Shovad buddy,you really shouldn't be gauging up on your residential unit,if you do not expell all the air from your gauges it will wind up in your unit,a bad thing.
If you gauge up in wet weather,you my entrain moisture,a very bad thing.
If you gauge up and the gaskets on your gauges are bad,you'll leak refrigerant,not only a bad thing but an EPA violation,subjecting you to a fine.
Please find a reputable guy (Angies list might be a start) and buy some piece of mind.
spring3100 is offline   Reply With Quote
very high suction pressure low head pressure ferguson58 HVAC 7 06-19-2012 12:10 AM
High suction pressure, low head pressure Italgrl HVAC 12 04-02-2012 12:50 AM
high head pressure low suction tcbaker72 HVAC 12 07-12-2009 10:10 AM
