Old 11-02-2009, 10:12 PM   #1
Default What the heck was the previous owner doing???
Found this during the home inspection, but ventured into the crawl space and took a closer look today.
The first pic shows a blower (ducting is feeding from the right) that was stuffed into the existing main line, would feed 3 registers in the downstairs family room. Ran off an extension cord (no longer present). As you can see, the ducts to the family room are not currently active.
The second and third pics show where the ducting used to come off the main and spur off into the downstairs bedroom. They put this blower here instead, again to be powered with an extension cord.
Any ideas what they might've been thinking?? There used to be a wood stove in the basement if that has any bearing.....
Thanks!
burnt03 is offline   Reply With Quote
Old 11-02-2009, 10:19 PM   #2
Master Plumber/Mechanical
Attachment are not loading
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 11-03-2009, 12:25 AM   #3
Should be working now?
Old 11-03-2009, 06:32 AM   #4
HillBilly Air Conditioning, would be my guess.
mark942 is offline   Reply With Quote
Old 11-03-2009, 06:36 AM   #5
An old Tradesmen
Looks like he used those blowers to get the heat from the basement up to the living areas.
Old 11-04-2009, 08:28 PM   #6
I agree. People can sure do some silly things. Although I understand what they were trying to do.
mikef54 is offline   Reply With Quote
Old 11-14-2009, 04:12 PM   #7
Bit of an update. My wife's cousin was over visiting the other day, he's an HVAC/refrig guy and said he'd take a look.
We ended up removing the blowers, capping the end of the main run with sheet metal and cutting the 3 take offs back into the main run.
So, now I've got some 6" circular ducting and I'm ready to go on my own but he suggested that I remove the old ducting runs and run a hose through them before hooking them up (pretty dirty and lots of spider webs).
Also noted that all the existing 6" runs are not screwed or taped up! Was under there today taping up some joints and it's amazing how much air is leaking out of the existing take offs. Too bad I can't get at the ducts supplying the upstairs!
Anyways, been using that silver tape to seal up the leaks. Should I just use self tapping screws to put everything else back together?
Thanks!
Old 11-14-2009, 04:39 PM   #8
old pro
Screw em and tape em is the best way.
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. If you looked at the duct test that we did earlier, you saw that we had hooked this hose right up here, this... Read More »
How to Do a Rough Duct Test
How to Do a Rough Duct Test by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. We are doing a rough duct test on this house. Rough duct meaning literally that the house being built is in the... Read More »
How to Find Total Duct Loss
How to Find Total Duct Loss by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Now we are looking for the total loss even the loss to the inside, even the loss where our tape might be leaking or... Read More »
Someone has said duct tape is like The Force (from Star Wars) because it has a dark side and a light side and holds everything together. Some people have taken duct tape out of the "holding things together" business and into fashion. People make all... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. Okay we've got a referenced hose that runs from that piece of duct and it is going to come over here and it is... Read More »
My house's previous owner - DIY horror stories Leah Frances General Discussion 17 07-20-2009 05:21 PM
New Home Owner Needs Help nho85 HVAC 3 06-30-2009 03:56 PM
bad vinyl patches by previous owner - how to smooth? pairadocs Building & Construction 1 05-17-2009 02:13 PM
Last owner put latex on oil- how to fix? Lib Painting 2 07-30-2008 07:02 PM
new home owner awider Introductions 7 09-23-2006 08:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
