What Is A "Heat Pump"? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 02:17 AM   #1
SELLC's Avatar
What is a "Heat Pump"?
I been reading more and more on this forum about heat pumps. I cant say I have ever seen one. From what I gather its a more efficiant way to cool a home?
How does this system work? Any photos?
SELLC is offline   Reply With Quote
Old 10-13-2009, 05:34 AM   #2
Rewards Points: 292
In non-technical terms, it is an air conditioner (outdoor condenser) which has the ability to switch functions with the indoor (evaporator) coil, so that in heating mode, the warm/hot air is expelled into your duct system, rather than to the outside air, during cooling season.
V
veesubotee is offline   Reply With Quote
Old 10-13-2009, 05:51 AM   #3
An old Tradesmen
Rewards Points: 7,808
Heat pumps are not more efficient at cooling a home, then a straight A/C is.
They are however. Often more efficient at heating a home then using oil or gas.
Old 10-14-2009, 07:01 AM   #4
It is likely you have seen a heat pump but did not know it. As you know, air conditioners essentially transfer heat from the indoor coil to the outdoor unit. A heat pump is essentially an oversized air conditioner which can reverse that process and transfer outdoor heat to indoors. It sounds counter-intuitive, but yes, you can extract heat from 30F outdoor air.
Since a heat pump is an air condition, but is designed for dual purposes, they are a little less efficient than true dedicated air conditioners when running in cooling mode. Because a heat pump, like an air conditioner, is truly a heat transfer engine, its thermodynamic efficiency is high when compared to other forms of heat, and can be more economical.
dac122 is offline   Reply With Quote
Old 10-14-2009, 12:14 PM   #5
Rewards Points: 150
dont some of these heat pumps switch between sources of heat depending on how cold it is outside? Say at 15celcius below (5 farenheit), the heat pump may turn off, and then youd rely on your oil furnace to heat your home. Is that correct?
sbmfj is offline   Reply With Quote
Old 10-14-2009, 12:22 PM   #6
Yes. As the outdoor air to indoor air difference increase, the discharge temp of the heat pump's indoor coil (aka lift) can get too low to overcome the structures needed BTUs, so the backup/auxiliary heat can come on. Also, some folks don't like the comfort the cooler air provides and so personal preference can sometimes dictate the backup/auxiliary heat to come on. Periodically the heat pump must go into defrost, which is essentially the system reversing itself back to A/C mode, and that is another occasion your backup/auxiliary is needed to temper the air.
Old 10-14-2009, 03:30 PM   #7
Rewards Points: 150
thanks for the explanation.
Old 10-14-2009, 04:14 PM   #8
More details. . .
http://en.wikipedia.org/wiki/Heat_pump
