Old 09-28-2009, 03:17 PM   #1
What is a good Air filter for the home?
I am using those cheap generic white filters from lowes and see dust all over my electronics. I replace them every 21-30 days and lately see alot of dust. What is a good filter for the home to use in place of these cheap flters?
N01B4ME is offline   Reply With Quote
Old 09-28-2009, 06:42 PM   #2
Hvac Pro
True blue Merv7 from HDepot or a Merv 8.
Old 09-29-2009, 05:43 AM   #3
An old Tradesmen
Atleast Merv 8 in the summer.
A wet A/C coil has the same filtering effect as a MERV 8. So you are better off having a filter that matches or exceeds that in the cooling season.
Old 09-29-2009, 08:58 AM   #4
Do I have to change these filters monthly as well?
Old 09-29-2009, 09:11 AM   #5
30 year tech
hvac122's Avatar
Another thought;
A furnace filter is only going to clean whatever air goes through it. If you have excessive dust then the problem is more than likely infiltration into your house. When we do blower door tests the leakage into the house is where most of the dust is comming from. Your attic needs to be sealed from the house to solve this problem.
hvac122 is offline   Reply With Quote
Old 09-29-2009, 03:32 PM   #6
An old Tradesmen
Most likely. How often any air filter needs changed, always depends on the home its in.
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 07:59 AM
Home Depot Classes; are they any good? RyanD General Discussion 16 04-28-2009 09:57 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
