What Are The Effects Of Having A 4 Ton Condensor Unit And 3 Ton Evap Coil? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 01:26 PM   #1
What are the effects of having a 4 ton condensor unit and 3 ton evap coil?
I looked closely at my current hvac setup and this is the case at my house.
I hava 4 ton outside unit and due to the small space available for the evap coil they put a smaller 3 ton coil in place.
What will this cause short and long term? anything immediately?
blarose is offline   Reply With Quote
Old 07-14-2011, 01:32 PM   #2
vln
Underwriter
They probably put less freon to balance out the pressure? I know my guy put in a 3 ton unit with a 4 ton coil and all is fine.
vln is offline   Reply With Quote
Old 07-14-2011, 06:37 PM   #3
Anybody knows what happens if the evap coil is smaller than the condenser?
Old 07-14-2011, 06:57 PM   #4
An old Tradesmen
Rewards Points: 6,464
Less refrigerant would just make the coil freeze up quicker.
Old 07-14-2011, 06:59 PM   #5
An old Tradesmen
Depends how much air the blower is moving. It may remove more moisture from the air, and work ok. But the system is NOT a 4 ton system anymore with that smaller coil.
Struggling with Home warranty company over evap coil, plenum, etc, please advise! JYale HVAC 7 04-12-2011 05:49 PM
Damaged fins on furnace EVAP coil rlukas79 HVAC 5 12-21-2010 04:10 PM
Evap Coil Replacement Rickhoff HVAC 3 08-24-2009 10:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
