-   -   What are the effects of having a 4 ton condensor unit and 3 ton evap coil? (http://www.diychatroom.com/f17/what-effects-having-4-ton-condensor-unit-3-ton-evap-coil-110737/)
blarose 07-14-2011 12:26 PM
I looked closely at my current hvac setup and this is the case at my house.
I hava 4 ton outside unit and due to the small space available for the evap coil they put a smaller 3 ton coil in place.
What will this cause short and long term? anything immediately?
vln 07-14-2011 12:32 PM
They probably put less freon to balance out the pressure? I know my guy put in a 3 ton unit with a 4 ton coil and all is fine.
blarose 07-14-2011 05:37 PM
Anybody knows what happens if the evap coil is smaller than the condenser?
beenthere 07-14-2011 05:57 PM
Less refrigerant would just make the coil freeze up quicker.
beenthere 07-14-2011 05:59 PM
Depends how much air the blower is moving. It may remove more moisture from the air, and work ok. But the system is NOT a 4 ton system anymore with that smaller coil.
