What Is The Correct Blower Speed Setting? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 09:42 PM   #1
What is the correct blower speed setting?
Hello all,
I have a 1.5 ton condenser and a Goodman GMP050-3 furnace and blower. According to the manual, the furnace is compatible with coils that range from 1.5 tons to 3.5 tons. The blower has 4 speeds: low, medium low, medium high, and high.
Here is a link to the fan curve for the furnace. It looks like the lowest curve there ranges from 700 to 850 CFM, which seems too high for a 1.5 ton condenser, even though the manual says the furnace supports it!
What setting should I have it on for cooling?
What setting should I have it on for heating?
Thanks!
Samber is offline   Reply With Quote
Old 06-23-2010, 05:48 AM   #2
An old Tradesmen
Rewards Points: 7,816
Set it to the speed that the temp coming out of the furnace in heating is 55 warmer then coming into the furnace.
Use same speed for both heating and cooling.
Measure temps at return plenums.
Old 06-23-2010, 07:10 AM   #3
Thanks for the reply! The temperature rise range for the furnace is 25 to 55, so is it correct to aim for 55?
Also, there are two different connections for heating and cooling, so I can't use the same speed for both, unless I changed it in the winter.
Is it ok to run the furnace in the summer?
Thanks!
Old 06-23-2010, 07:20 AM   #4
An old Tradesmen
Shoot for 40 to 45 then.
Need a twinning/doubling connector to run both heating and cooling at the same speed.
You can run a gas furnace in the summer. Doesn't hurt anything. Just heats up the house a little faster then in winter.
Old 06-23-2010, 10:55 AM   #5
Ok, so if I get the heating split correct that will be the correct cooling CFM as well?
Also, the circuit board has four terminals: Heat, Cool, M1, and M2. The two speed setting wires that are not hooked up to heat or cool are on M1 and M2. Is it ok to hook any of the speed wires to either Heat, Cool, M1, or M2?
Old 06-23-2010, 11:01 AM   #6
An old Tradesmen
M1 and 2 are park terminals. Thats where you put the unused speed wires. So they don't dangle and get drawn into the blower.
If you have 2 speeds that get you close to the 45 rise, You can use the one that gets you the hire temp as your cooling speed.
The blower at a 45 rise will be moving about 800CFM. For your 1.5 ton it should be a bit less though.
Check the temp rise at all speeds and post back what they are. And I can tell you which ones are best for heat or cooling.
Often on small furnaces though, the same speed works out best for both heating and cooling.
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 08:44 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Comfortmaker blower problem rerobins HVAC 2 01-06-2010 10:38 AM
Adjust blower speed? Model and pic inside. ls3c6 HVAC 10 07-07-2009 12:27 AM
variable speed blower satishprabhu HVAC 1 07-01-2009 11:32 AM
