What Can An Attic Fan Do For This House? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 01:46 AM   #1
Rewards Points: 682
What can an attic fan do for this house?
My brother has an old house in San Jose, CA. It get very hot in summer, and they have a hard time sleeping because of the heat.
They are thinking of installing an attic fan. I was wondering how much of a difference would an attic fan make in the house, maybe reduce temps 10 degrees farenheit? Are there better solutions such as repairing the attic insulation? And what kind of costs should he expect to pay a contractor to do the job for him?
darsunt is offline   Reply With Quote
Old 06-21-2009, 07:04 AM   #2
An old Tradesmen
Rewards Points: 7,746
Might help, might hurt.
Depends how well sealed the attic is from the house.
Adding insulation never hurts.
Old 06-21-2009, 07:07 AM   #3
biggles's Avatar
if you can cycle the air out of the attic with the night temperature it will keep the house slightly cooler after the sun has been beating on the roof all day.if they do a ceiling fan(low speed)and a window unit(set at 75F) in the bedroom that will be a total change.if money is an issue...try the attic fan first,and then a ceiling fan second and check out the results.keeping the blinds tweeked so no sun hits the walls or shows anyplace in that room also helps.... if they are on a west exposure in the PM.on that attic either just venting the eaves or installing a forced fan will dump some of that 100F build-up
Old 06-21-2009, 10:20 AM   #4
"1. Lowers upstairs room temperatures by 10."
You want it, you got it. . .
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Whole House Fan Ideas? stevedar HVAC 2 06-20-2008 01:59 AM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
