What Is The C Thermostat Connection On Carrier Furnaces - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 01:15 PM   #1
What is the C thermostat connection on Carrier Furnaces
I am installing a new thermostat, one that requires a C connection, and I do not see it on the furnace.
Furnace: Carrier Performance 93
Furnace Connections: W2, Y1, DHUM, G, Com 24, W/W1, Y/Y2 and R
Thermostat: Honeywell RTH6580WF
mikeklement is offline   Reply With Quote
Old 08-28-2013, 02:44 PM   #2
Rewards Points: 42
The C connection is the Common wire. On your list it's the Com 24.
Dan
djlandkpl is online now   Reply With Quote
Old 09-07-2013, 10:16 AM   #3
Rewards Points: 77
It is one of the 24V wires from your transformer in the furnace. This wire is used to provide constant 24VAC to the thermostat so batteries are not required.
On the list of connections you listed it is Com 24. To connect it you will need to connect one of the wires from the thermostat wire bundle to the Com 24 terminal and the other end of that wire to the "C" terminal on the thermostat. Before doing this turn off power to the furnace so you don't blow the 3A or 5A fuse on the low voltage control side. The common color used on a lot of systems is blue. But it can be any of the wires you have in the thermostat wiring bundle that is not used. If you have no extra wires then you will need to run a new one from the furnace to the thermostat.
firedawgsatx is offline   Reply With Quote
Tags
performance 93
Thermostat Replacement kgreen4me Electrical 2 01-27-2013 11:46 AM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
E2 code on Carrier OMTSTAT_3 thermostat strikeeagle HVAC 13 05-15-2011 01:42 PM
looking to update my thermostat, whats compatable with my carrier system detyianni HVAC 11 12-26-2010 11:44 PM
Carrier Infinity Thermostat PeterG HVAC 11 11-15-2009 05:04 PM
