What brand of furnaces do you work on? R u brand specific?
Do you guys generally work on your own promoted brands of furnaces exclusively these days given that many newer make furnaces seem to have proprietary parts now or do you service all makes and models?
One tech I spoke with said years ago, he would carry standard parts in his truck and be able to service most furnaces out of his truck but with the newer design setups, you have to diagnose and then source proprietary parts to do a second service call. Do most brands all work the same but just not allowing interchangeable components? My point is should I only call a Lennox approved tech for my Lennox or brand X? The other consideration is if I find a good tech that I trust but I want a brand of furnace that has features i want but that he does not promote, would he still be ideal to do the install? |
I will work on anything other than a Rheem/Ruud mod. totally different than any other unit as it uses varying voltages to the gas valve and their special varying voltage tstat and U need their hidden tech info etc. It is best to stay with the brand the installer recommends as he can set it up properly. Other than the mods most guys should be able to fix most other brands. Getting the service manual and info is usually the big problem.
It all comes down what you want to spend. Do you want a high end a/c and high end furnace. Then you look who has better warranty plan. Then you look and see you has a better rebate going on at the time of replacement. Then you want to check B.B.B. who in your area had outstanding rating. Then look into that company and see what offer like warranty them self. Some company will offer to the warranty . Sorry this should be on top but if you are looking to live were you are now. Just put in 80% and 13 seer a/c. But you planning living there more then 10 years then look into the high seer a/c is offer and 90% (or higher) so you see the unit paying it self off. That would be me if I was you. Good luck happy hunting .
I chose my local brand after being in business for 15 years. Brand A,B,C has no parts support, their warranty policies suck, however, brand D-warranty is good(and I am not talking about consumer warranty-DOA) and it's all local.
Back when I started I would put any manufacturer you wanted in your house. Today...I know who is going to support me as a business and If you want a Trane, Rheem, Ruud, Goodman, American Standard or any other brand that is not well supported in this area...good bye....Other than parts I am not going to deal with them. Especially Trane who thinks their stuff is gold plated.:yes: |
I'd like to deal Trane, but I am not sure the powers that be (Uncle)would allow it.
So I push my second fav which is Gibson,Frigidaire, and Westinghouse. They are well designed but not as quiet as some of the others. |
That's why Uncle has it in for some of the larger mfg. |
| All times are GMT -4. The time now is 02:01 PM. |
