What Is This On The Bottom Of My Boiler Chimney?[pic] - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 09:01 PM   #1
Rewards Points: 150
what is this on the bottom of my boiler chimney?[pic]
For the first time i opened up the little clean out door on the bottom of the chimney for my oil fired boiler, expecting just to clean it out- but i found this in my way.
seems to be made of concrete, and fixed there in a permanent fashion.
Looks to be made of cement.
any idea what i am looking at here?
how am i intened to get a vaccum in there to clean out soot?
alecmcmahon is offline   Reply With Quote
Old 12-07-2010, 09:08 PM   #2
Concrete & Masonry
Rewards Points: 576
The orange is a clay flue liner. What's inside appears to be alot of excess mortar. How much is the question. I would tap on the flue liner with a hammer at the top to see if it sounds hollow or not. If hollow, merely bust a decent sized hole in it to vacuum out.
jomama45 is offline   Reply With Quote
Old 12-07-2010, 09:10 PM   #3
Rewards Points: 150
Ok, so no harm in busting a hole where it looks like somebody already tried ?
Old 12-07-2010, 09:12 PM   #4
Concrete & Masonry
Rewards Points: 576
In all honesty, no harm what-so-ever in busting a hole into the flue anywhere UNDER the thimble where the boiler pipe enters.
Old 12-07-2010, 09:16 PM   #5
Rewards Points: 150
Sounds good, Yeh the Duct out of the boiler doesnt enter the chimney stack for another 3 feet or so above the clean out door.
Old 12-08-2010, 09:01 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... So instead of makin' More work for yerself,...
Pull the smokepipe from the boiler, 'n clean the chimney from There.....
Bondo is online now   Reply With Quote
Old 12-08-2010, 12:38 PM   #7
Rewards Points: 1,596
Would putting a hole there interfere/mess up the draw of the flue? Could that cause exhaust gases to re-enter house? I don't know, just asking.
bob22 is online now   Reply With Quote
New boiler (maybe) secutanudu HVAC 40 12-01-2010 05:29 PM
Replace boiler coil Daniel Holzman Plumbing 2 11-26-2010 05:53 AM
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Boiler room venting dontilgon HVAC 19 12-07-2009 05:07 PM
Removing old oil boiler and radiators 71Whaler HVAC 4 05-28-2009 07:14 AM
