What Blew Out Of AC Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2015, 11:09 AM   #1
Rewards Points: 2,188
What blew out of AC vent?
This house had heavy smokers. 59 cig burn marks on LR carpet. One outlet receptical had same brown coning out of it.
What blew out of the ceiling vents to leave those brown marks? I think if there was a fire smoke stains would be gray. How could someone smoke enough in a 15 yo house to cause this? Thanks
Startingover is online now   Reply With Quote
Old 02-07-2015, 11:23 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 150
It could be nicotine and I have seen some walls coated in it. After 35 yrs in the biz I have seen everything other than a dead body.
It also may be that the return duct in the attic is not sealed properly and could be sucking in dirt and mixed with the smoke is brown. Looks like brown smoke covered dust to me.
Nicotine is horrible and unless you wash the walls the stench never goes away. It is also coated on the inside of the ducts and airhandler/ AC unit and near impossible to get rid of. I would look for a different house if you are shopping for one.
The Following User Says Thank You to yuri For This Useful Post:
Startingover (02-07-2015)
Old 02-07-2015, 11:30 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
I was a heavy smoker myself for years. The smoke settles out on the walls and ceiling and is very tacky. The airflow over this sticky stuff will deposit other dust on it.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 02-07-2015, 11:59 AM   #4
Mad Scientist
I've seen newly turned apartments turn completely brown/yellow after only one year of a smoker living there. Nasty stuff.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
Old 02-07-2015, 12:14 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 150
I have seen it coat the inside of return and supply ducts. It is filthy and unless you replace the ductwork it is there 4ever.
Old 02-07-2015, 12:25 PM   #6
PoleCat's Avatar
If you are committed to a clean it up approach it can be done but is only for those with a ton of time. Formula 49 and similar cleaners will cut the tar. We had a few units that were as bad as it gets and under orders to clean them. We used a commercial degreaser and a wet vac on the walls & ceiling. The flooring had to be replaced. Luckily the units were heated/cooled with Zoneline equipment so we just took those to the shop and sanitized them.
It was a monumental chore but we succeeded.
Old 02-07-2015, 12:35 PM   #7
Rewards Points: 446
The air leaving the registers causes a slight static charge on the surfaces it contacts and makes particles, like smoke, stick to them.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
Old 02-07-2015, 01:05 PM   #8
Rewards Points: 38
after cleaning, if you are going to repaint use a good primer made to cover smoke stains. The schallac based BIN is the best. It is alcohol based and has an odor but it works. $$$$ it is expensive.
bernie
bernie963 is offline   Reply With Quote
The Following User Says Thank You to bernie963 For This Useful Post:
Old 02-07-2015, 02:01 PM   #9
Thanks guys.
This house will go into the "NO" category.
Old 02-07-2015, 02:40 PM   #10
An old Tradesmen
Rewards Points: 7,816
Looks like the registers aren't sealed to the ceiling. And the dust is being drawn in from the attic/ceiling cavity.
The Following User Says Thank You to beenthere For This Useful Post:
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
