What Is The Best Way To Put 3/4" Radiator Line Through Wood? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2008, 11:22 PM   #1
What is the best way to put 3/4" radiator line through wood?
Need some experienced advise.
Before I run my zone lines in my crawlspace to my baseboard's 3/4" copper stubs which come through the floor from the living space above, I need to put in my baseboard first. What is the best way to drill through my wood floor for the 3/4" baseboard radiation lines? How big a diameter hole, and how should I finish the hole around the copper pipe?
Mike Warner
Mike Warner is offline   Reply With Quote
Old 04-17-2008, 08:16 AM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Just because it is 3/4 doesn't always mean that is the size to drill. Get out all the drill bits you have in that general size and hold it up to the pipe to check a go/no go situation. You can also get some escution rings to go over th pipe to fill any gaps. You might want to look at those rings before you hog out a 1 1/2 hole though. They may not fit your decorating taste.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-18-2008, 12:18 AM   #3
Thanks for the reply Cal.
Mike
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
regular roofing asphalt paper under 3/4" wood floor? zel Flooring 4 07-13-2007 12:02 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
