-   -   What is the best way to put 3/4" radiator line through wood? (http://www.diychatroom.com/f17/what-best-way-put-3-4-radiator-line-through-wood-20023/)
Mike Warner 04-16-2008 10:22 PM
Need some experienced advise.
Before I run my zone lines in my crawlspace to my baseboard's 3/4" copper stubs which come through the floor from the living space above, I need to put in my baseboard first. What is the best way to drill through my wood floor for the 3/4" baseboard radiation lines? How big a diameter hole, and how should I finish the hole around the copper pipe?
Mike Warner
jcalvin 04-17-2008 07:16 AM
Just because it is 3/4 doesn't always mean that is the size to drill. Get out all the drill bits you have in that general size and hold it up to the pipe to check a go/no go situation. You can also get some escution rings to go over th pipe to fill any gaps. You might want to look at those rings before you hog out a 1 1/2 hole though. They may not fit your decorating taste.
Mike Warner 04-17-2008 11:18 PM
Thanks for the reply Cal.
Mike
