What Is Best Furnace Filter To Buy? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 10:05 AM   #31
Very informative thread, I've learned quite a bit.
In my apartment I've got an old furnace (manufactured in '86 installed in '91) and just yesterday the ancient washable filter disintegrated on me (cheapskate landlord)when I was washing it, so I had to replace it.
Before reading all of this I headed to the local hardware store to pick up a new one. They had three choices, one which was rated at MERV 11, which I bought and installed. After reading this I'm thinking 11 might be a little high for the old girl. I went back to the store and the filters that were more expensive were the Filtrete ones rated at 1000 (MERV 10 if I understand correctly), and the only other option were the True Blue ones rated at MERV 2. Which of these should I get? Is MERV 10 probably still too high for an older furnace, and will one with a rating as low as 2 present any problems?
Any help appreciated.
AClogston is offline   Reply With Quote
Old 02-13-2011, 10:31 AM   #32
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
I would never use any filter higher than a MERV 8 on any furnace unless it has a powerful ECM motor or large ductwork which lots of people don't have. (tests needing doing to make sure if a higher grade is used). True Blue makes Merv 7 and 8 at HDepot. I buy them there for my neighbor. Also at Canadian Tire in Canada. Merv 7 is good for yer ol gal. 2 is better than nothin but not much better.
The Following User Says Thank You to yuri For This Useful Post:
AClogston (02-13-2011)
Old 02-13-2011, 11:25 AM   #33
Thanks yuri, I will try to find something around 7-8 ASAP. The 2 won't harm the furnace in the meantime will it?
Old 02-13-2011, 11:27 AM   #34
Hvac Pro
yuri's Avatar
No.....
Old 02-13-2011, 01:10 PM   #35
Rewards Points: 77
I couldn't agree more...MERV8 unless there is an ECM motor of sorts to overcome the static pressure
AirstarFilters is offline   Reply With Quote
Old 02-13-2011, 01:48 PM   #36
An old Tradesmen
Rewards Points: 6,570
Those see through blue fiberglass air filters were used for a long long time before those 3M came out.
It won't hurt the furnace.
Old 09-16-2012, 08:55 PM   #37
Not all Metal (Electrostatic) Filters are created equal
I realize this is an old post but I have had a lot of experience with electrostatic filters. Keep in mind that several manufacturers make electrostatic filters and each has it's own specs and design. Like any filter, there is a balance between dust capture and airflow. I used dusteater brand at home and did not like it...to much resistance. I have also learned to ask my customers if they are good at remembering to change their furnace filters. If they forget for months at a time, I do not recommend any permanent filter. Most of my older customers have a good routine for checking their filter every month. In this case I have found that the boair brand electrostatic filter works very well. It has very low resistance to airflow and traps dust well. The unique thing about boair is it contains 5 layers af thin media and no polyester so it is easy to wah clean. I've been using them in my units at home for about 10 years.
ALPINEHVAC is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Going from 1 inch furnace filter to 5 inch furnace filter. BorgVilla HVAC 11 01-24-2011 05:17 PM
Rigged my furnace for a different type of air filter, bad idea? mibson HVAC 9 01-16-2011 01:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Furnace minus filter dsal HVAC 16 02-24-2008 01:26 PM
