Wet Bulb And Dry Bulb - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 04:08 PM   #1
wet bulb and dry bulb
why do you need to know the wet bulb and dry bulb is in hvac and why are they important
astovall is offline   Reply With Quote
Old 09-02-2012, 04:44 PM   #2
JJboy's Avatar
You need Wet bulb temp at the return air vent and Dry bulb temp of air into condenser to proper find the target SH AND SC.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
astovall (09-03-2012)
Old 09-02-2012, 05:54 PM   #3
HOTDAWG
which is used to properly charge the system
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 09-02-2012, 09:22 PM   #4
JJboy's Avatar
This will depend if your AC system has fixed orifice or TXV.
Old 09-02-2012, 09:35 PM   #5
Missouri Bound's Avatar
Homework??
Do you want it your way or the right way?
Old 09-03-2012, 06:00 AM   #6
An old Tradesmen
Rewards Points: 6,072
What can you convert Wetbulb to?
Fixed metering device SH is base on the indoor _____ heat.
