Wel McLain Boiler:In Need Of Advise - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 12:23 AM   #1
Wel McLain Boiler:In Need of advise
I have the Weil McLain/ P-CG-7 Model. This afternoon I had shut off the heat, to open windows around the house to air out my home. The issue is after shutting off thermostat, now boiler is not turning on. Pilot was lit, though was not firing up. I now have shut off the gas.
Any advise/assistance is appreciated
ceceil is offline   Reply With Quote
Old 03-27-2011, 10:17 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
if it is a standing pilot system then you need to see what limit has tripped. With the stat calling for heat and the pilot on check for 24V at the gas valve. if you dont have 24 volt there, then check the limits to see if they tripped.
http://www.weil-mclain.com/en/multim...gcginstall.pdf
PER what the picture above, you only have a high temp limit as something that may be tripped. Ensure there is power to the boiler.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ceceil (03-27-2011)
Old 03-27-2011, 11:03 AM   #3
fabrk8r
fabrk8r's Avatar
I'll agree with hvactech. I was going to say get a new thermocouple, because it's a common problem with these units, but then I saw that you said the pilot was lit.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
ceceil (03-27-2011)
Old 03-27-2011, 12:10 PM   #4
Thank you guys for responding, and for helpful info
I had talked with my oldest son this morning and he is calling his father in law to come check it out, he does this for living. I had shut down gas to boiler, cause was not sure of any gases or fumes escaping from unit with just pilot being lit. Just thankful, it does not control hot water, is just for heat, and spring weather is on its way, is bright side.
Again thank you for responding and advise.
Ceceil
Tags
weil mclain
Need advise with these bathrooms zxc1251 Off Topic 1 08-25-2010 07:49 AM
Need help and advise pic included wolverine HVAC 15 07-01-2009 05:20 PM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 11:05 AM
Weil Mclain Boiler air in system manning01 HVAC 11 10-06-2007 11:35 PM
Needing some advise..... wooody_1 Flooring 6 10-25-2006 09:14 AM
