Old 12-28-2008, 05:51 PM   #1
Weil-Mclain boiler question
Hi,
I had a new Weil-Mclain boiler installed last fall. The model is a CGi-4. They installed it using a primary and secondary loop with each loop having a circulating pump. When the boiler is engaged both pumps run at the same time. My question is that I thought only the pump on the primary loop ran all the time with the pump on secondary loop turning off and on when the burners fired. When the boiler was installed was it not wired quite right or is this boiler not capable of turning the secondary pump on and off?
Thanks for your input
JJ
Boiler1 is offline   Reply With Quote
Old 12-29-2008, 12:25 AM   #2
An old Tradesmen
Both pumps are suppose to run at the same time.
The burner cycles on and off so as not to over heat the water.
If its circulator also shut off, then you wouldn't get any heat to your heating loop.
Its wired, and working properly.
Weil Mclain Boiler Banging After Water Circulator Swap Roamer HVAC 6 12-11-2008 07:42 PM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 11:05 AM
Weil Mclain Boiler air in system manning01 HVAC 11 10-06-2007 11:35 PM
Weil McKain boiler size my5cats HVAC 1 02-24-2007 05:38 PM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
