Weathermaker 9200 Install Instructions? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 09:20 AM   #1
I just purchased a run down house with a Weathermaker 9200 furnace/ac unit. The condensation drain lines were not installed correctly and the pump has blown. I've tried to find install instructions how the lines are supposed to be run but I unable to. Does anyone know a website with install diagrams for this unit without having to pay for them? Nothing in this house was installed correctly - any help would be much appreciated.
DRK008 is offline   Reply With Quote
Old 08-22-2013, 11:28 AM   #2
HVAC Tech/Owner
Rewards Points: 604
How do you know they were not installed correctly.....if you don't know what correctly is?
Technow is offline   Reply With Quote
Old 08-23-2013, 08:29 PM   #3
Rewards Points: 77
Try this:
http://www.docs.hvacpartners.com/idc.../58mxa-4si.pdf
http://www.albeyers.com/pdf/58mxa.pdf
The second site is to show you that the Weathermaker 9200 and 58MXA are the same unit.
firedawgsatx is offline   Reply With Quote
Carrier Weathermaker 9200 problem alinniles HVAC 4 12-03-2012 07:31 PM
Carrier weathermaker 9200 jrobins1 HVAC 8 12-01-2012 01:49 PM
Carrier Weathermaker 9200 error code 31 Espo HVAC 2 03-17-2012 01:45 PM
LP to NG conversion for Carrier Weathermaker 9200 MXA dinoflash1 HVAC 1 09-17-2011 09:54 AM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 06:01 PM
