Weathermaker 8000 58wav: Part Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 10:19 PM   #1
Weathermaker 8000 58wav: part needed
I need to replace the part below. It spins like it should right before and during heating cycle; however, it wobbles and makes a lot of noise. What do I need and what would it cost to replace this part? It seems like a plastic wheel held onto a spindle with a retaining clamp.
Weathermaker 8000 58wav: part needed-unknown-part-needed-weathermaker8000.jpg
Saveme$ is offline   Reply With Quote
Old 01-09-2012, 12:11 AM   #2
REP
Get the venter assy.If the blade is wobbling then there is a better than 50% chance the shaft is loose also.
Replacing the assy is also easier to do then replacing parts of the assy.
REP is offline   Reply With Quote
Old 01-09-2012, 08:03 AM   #3
im 95% sure i have a used one here, im near toronto
Legacyairsystem is offline   Reply With Quote
The Following User Says Thank You to Legacyairsystem For This Useful Post:
Saveme$ (01-15-2012)
Old 01-15-2012, 01:57 PM   #4
Please private message me your details.
saveme$
Old 01-15-2012, 01:59 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
take the spring clip off ( squash it carefully and then restraighten later) and then smear red high temp rtv silicone on the shaft and then put the wheel and clip back on and let it cure for 2 hrs. the plastic in the wheel wears and some were loose from Day 1. silicone at auto parts store.
The Following User Says Thank You to yuri For This Useful Post:
how (01-31-2012)
Old 01-15-2012, 02:02 PM   #6
The shaft seems fine. It's the retaining nut thingy that makes the wheel "wobble." It spins and spins but makes a lot of noise. I took off the nut thingy and tried to straighten it but the noise is still there.
Old 01-15-2012, 02:05 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 396
that thingy is a cheap piece of sheet idea. silicone it on. I had to do that with brand new ones, unless you want to spend several hundred $$ on a new motor and wheel. those units spin at over 3000 rpm and wear and buying used is not what I would do.
other than that it is a pretty good furnace.
Old 01-15-2012, 02:13 PM   #8
Do you think Home Depot or a parts store would have the nut thingy? Mine is bent and warped.
Old 01-15-2012, 02:17 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 396
its possible but somewhat unlikely. trust me some silicone on the shaft and thingy and you will be fine. Y make it more complicated than necessary? ever hear of MacGyver or RedGreen?
Old 01-15-2012, 02:25 PM   #10
True. MacGyver used to make exposives out of Coca-cola bottles and strawberry Hubba-bubba gum.
Any old silicone or another?
Old 01-15-2012, 02:30 PM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 396
high temp ONLY as the shaft gets very hot from the heat of the smoke transfered to it by conduction. auto parts stores may have it for exhaust manifolds etc, permatex brand?
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old 01-15-2012, 02:57 PM   #12
http://www.canadiantire.ca/AST/browse/4/Auto/AutoRepairAccessories/Adhesives/PRDOVR~0383717P/Permatex+Black+RTV+Silicone+Adhesive+Sealant,+80+m l.jsp?locale=en
Thanks.
Old 01-15-2012, 03:17 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 396
yer welcome.
Old 01-16-2012, 06:53 AM   #14
When I put the silicone onto the nut thingy, should I also put some on the wheel? How far fro the back of the shaft should all of this go? the wheels spins and I see evidence that it is rubbing on the back and this is likely causing me noise.
Old 01-16-2012, 07:01 AM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 396
the shaft usually has a flat spot and the wheel has a matching notch. just put a thin layer on the shaft and slide the wheel onto it. U will see it start to ooze forward. then put a dab on the thingy and shove it on. the wheel should stop where the notch ends otherwise if it is really worn then U have to decide on a spot so it does not rub. if it is still loose remove it and add more silicone.
Ducane furnace part number needed mmcgirr HVAC 7 02-13-2011 01:54 AM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
Older water softener part needed dminden Building & Construction 2 05-19-2010 08:27 PM
Hot Water baseboard part needed (images) bmac1967 HVAC 6 01-04-2010 08:53 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
