#1 |
Weatherking pressure switch stuck closed error code
I have a weatherking furnace. The furnace intermittantly will not start at night when it's very cold. The control board is flashing four lights which is saying the pressure switch is stuck closed. I recently installed a new pressure switch and hoses so I know they are not clogged. I checked and the switch is actually open but the control board still says it's closed. I also have a new control board so I don't think it's bad. I know the pressure switch is wired through a control transformer and a little black box (pressure switch delay timer). If I wiggle the wires on these it will usually fire up after I reset it and run for a week or two. Is it possible one of these are bad and how can I test them to know for sure? Why would this only happen when it is very cold at night? I know they don't cost much to replace but I don't want to be throwing money away.
| Tags |
control transformer, delay timer, pressure switch, weatherking ![]() |
| Display Modes | |
| pressure switch is open | slowplayed28 | HVAC | 2 | 10-31-2010 09:43 PM |
| fan/light switch buzzing | mjlocat | Electrical | 4 | 05-23-2010 03:44 PM |
| maybe not the pressure switch? | notsteve | HVAC | 2 | 01-07-2010 12:21 PM |
| Modification to an existing pump switch | DRBLKJK | Electrical | 10 | 08-23-2009 04:06 PM |
| RUUD Gas Furnace Pressure Switch? | erik11 | HVAC | 8 | 12-07-2006 12:39 AM |
