Weatherking Furnace Won't Cut On - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 07:07 AM   #1
Weatherking furnace won't cut on
I have a Weatherking furnace (not sure of the model) and its not cutting on. I did some trouble shooting and still can't figure out the problem. I tested all the high voltage, the breaker, furnace and door switch, and furnace fuse. I tried jumping the r and w wires on the thermostat too. I even checked the fuse on the circuit board. The circuit board is not lighting up to show any faults. I'm sure it's a low voltage problem. Does anyone know what I should check next?
mellemel1 is offline   Reply With Quote
Old 11-08-2013, 09:45 PM   #2
Rewards Points: 582
get us some pictures of furnace with doors off,,this will help us help you...ben sr
Old 11-09-2013, 07:14 AM   #3
Rewards Points: 1,214
Sounds like a bad control transformer. Find the transformer and wires on the primary side(High Voltage) check to make sure power in.
Now find the low voltage side(24 volts) and test it to see if it's bad. If you own a meter.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-09-2013, 08:05 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
check power into and out of the transformer
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Chimney flue relining or another option - Oil Furnace Expert Needed thp HVAC 22 11-08-2013 10:18 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
