Originally Posted by bobnorman76
Got it Done!
The old weatherking has now been running for two weeks straight without a problem. It must have been the control board and adding the flame sensor the way I did seems to be holding up just fine. I hope this helps someone out there. Thanks for all the help and suggestions. Thank God!
I read your post on relocating the sensor after i posted my msg about the heat exchanger recall.
What you have done is render your furnace safety certification null.
There are several after market boards available to fix your problem that your hvac contacts evidently didn't know about.
You run the possibility of having your furnace malfunction to the point of the gas valve passing unburnt into your heat exchanger literally turning it into a bomb.
You have made a major alteration that would normally be submitted to AGA for testing before it is deemed safe.
There is reason had such a great deal of time invested before you got it to light: it was meant to be repaired in only a certain manner to keep it safe.
You have a potential bomb on your hands.
