Weather Maker 9200 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 09:48 PM   #1
I just got a house which has a Weather Maker 9200 Furnace (gas).
Is it only for heating or does it also have cooling capacity in Summer?
The thermostat indicates that it is capable of both. How do I know or test the AC functions in a cold weather? Any thought will very much be appreciated. Thanks.
-Benoy
benoy is offline   Reply With Quote
Old 12-07-2009, 12:14 AM   #2
Houston204's Avatar
Rewards Points: 556
The weathermaker 9200 is a furnace, the addition of a condenser (outside) and evaporator coil add cooling capability.
Houston204 is offline   Reply With Quote
Old 12-07-2009, 07:58 AM   #3
Weather Maker 9200
Thank you very much Houston204. You have cleared up my confusion.
It is just for heating because I see no addition of condenser outside of the house. I really appreciate your reply.
Old 12-07-2009, 10:41 AM   #4
I'm in the same position: forum noob having just bought a house with this furnace. My question is about heat during a power outage and/or furnace outage. What options do folks consider the best? K1?
I assume the Weathermaker 9200 doesn't run on gas only, but requires electricity as well to run, right?
wavy_glass is offline   Reply With Quote
Old 12-07-2009, 06:07 PM   #5
When the power goes out you will not have heat. A power inverter is a handy thing to have around just in case something like that comes up.
Old 12-07-2009, 08:03 PM   #6
About 1 kw.
carrier 9200 furnace water leak maryjo HVAC 5 11-26-2009 06:58 PM
Weather King Furnace Not Working jbickmann HVAC 1 10-22-2009 07:53 PM
Carrier weather maker 9200 furnace NO 24 volts mmtuxedo HVAC 1 09-25-2009 06:49 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
