Weather Maker 8000 2 Spd Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 01:14 PM   #1
Hello...
I having problems with my weather maker 8000 heater unit which has been in this home for as long as we've lived in it (5 years) and unit shows flashing red lights of code 45 (replace control). What control is this referring to and can I replace this myself? thanks!
hodgeviper is offline   Reply With Quote
Old 12-29-2009, 11:17 PM   #2
I would image they mean the furnace control, the electronic board that controls the different functions of the furnace. I have a Weather Maker 8000, model 58DLA. There is no code 45 on the trouble shooting flow diagram. However, "replace furnace control" is the last item on the check list and one only get there after all preceeding test have been successfully passed.
What is the specific model number of your Weather Maker 8000? Do you have any documentation on it (users manual or guide, service and maintenance manual, etc.)?
hobbsje is offline   Reply With Quote
Old 12-30-2009, 11:09 PM   #3
Weather Maker 8000 Model
Thanks Hobbsje for the quick response...
I found a label inside the furnance with the model type for this weather maker 8000, the model is 58TMA06512.
hope this info helps...thanks again,
Fred
Old 12-31-2009, 01:31 PM   #4
Hope that helped you, Hodgepiper. I went to the Carrier web site and found three documents for the 58TMA Weather Maker furnace (See link below). The docs are not as detailed as the ones I found for my furnace but it does verify, to my satisfaction, that the control that is to be replaced is the "furnace control". It can be identified by the red (maybe yellow) LED that it resides on. Also on the furnace control you should find an automotive type fuse.
If you decide to replace it yourself, make sure you label all the wires in such a way you will know where to put them on the new control board.
Good luck!
http://www.commercial.carrier.com/co...8_QRYY,00.html
Old 12-31-2009, 03:57 PM   #5
Weather Maker 8000 Furnance
Thanks Hobbsje,
I know exactly where this control board is located, some how my wife & daugther were able to get the furnance running, but still I will have to replace this control board. Thanks very much for your research & asisstance I feel alot better knowing the info comes from a true professional.
Happy New Year!
hodgeviper
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 09:28 AM
Kenmore (Whirlpool?) Ice maker problem reddog6 Appliances 4 10-09-2011 06:11 AM
Whirlpool Ice Maker Heater Dead Mtn4Mike Appliances 0 12-16-2009 09:13 PM
Whirlpool Ice Maker Problem Aquin Appliances 5 03-26-2008 12:59 PM
Weather Head problem. integlikewhoa Electrical 5 02-18-2008 11:08 PM
