Weather King Furnace Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2009, 07:31 PM   #1
My weather furnace is not working anymore. it was working fine last week and now nothing. When troubleshooting I have determined the following:
The thermocouple is brand new, the pilot less ignition is working, (the pilot lights automatically when the power to the furnace is turned on) the blower works when set to "on" at the thermostat. When I call for heat at the thermostat it clicks as it always has to send a signal to the furnace. What next?
Thanks,
jbickmann is offline   Reply With Quote
Old 10-22-2009, 07:53 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like you are having a gas valve sticking
Make a call for heat, let the pilot lite and then stand to the side of the furnace and take a screw driver and lightly tap on the gas valve and see if it opens.
If it does replace the GV
If it does not take a volt meter, set meter to AC, one lead to furnace case and the other lead to the wires going to the gas valve. Voltage should be 24 Vac on both terminals
If you dont have 24 vac on both terminals disconnect power to furnace, remove wires to gas valve and measure the resistance between the two terminals
Post results
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Tags
furnace wont ignite
Lennox Furnace G27M Series Ė Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace blower not working right. oiljumper HVAC 4 11-10-2008 10:22 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
