Originally Posted by beenthere
Did you look on both sides of the coil to see if its clean. Thee can also be dirt in between the fins that you can't see.
Yeah, its not dirt-free, but definitely no clogs on both sides.
If your duct is lined. You can add insulation to the outside. Use a foil warp, so you have a vapor barrier.
I'm up for redoing the insulation, but I think I should strip the old so I can fix any bad taping (if there is any.)
What size are your 3 returns?
Two are "regular", maybe 16", and the one in the hallway is very long, maybe 32".
@Yuri, I agree 100%, it needs a service and a professional opinion, but I was trying to avoid that in this heat wave. I would imagine they are charging extra right now.
