Weak Air Floor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2015, 06:58 PM   #1
Rewards Points: 14
Weak air floor
I'm getting 73 at the registers during heating season fan not moving at full speed. Unit works well and strong air flow when switch to AC. 3 ton goodman rtu.
Mozart609 is offline   Reply With Quote
Old 12-06-2015, 07:19 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Need to measure temp at the return and supply are at the furnace. Within 3 ft of the furnace to see if the temp rise correct.
Just because the blower motor turns at different speeds between a/c and heat doesn't mean there is a problem.
Need to check temp rise at the furnace
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 12-06-2015, 08:33 PM   #3
Rewards Points: 582
heating speed...low- med...cooling most likely high..as mentioned need to make sure temp rise is within limits...
Old 12-06-2015, 09:04 PM   #4
Rewards Points: 14
Ok. Will look into that in the am. It's been hard for the unit to get up to temperature for several weeks now. But will let you guys know what I find
What is the minimum floor space required for a winder staircase vestaviascott Building & Construction 27 05-01-2015 10:36 PM
strengthening Weak plywood floor jpaz Building & Construction 7 10-17-2011 09:52 PM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 06:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
