WBV/WV Peerless Steam Boiler Is Thirsty! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 06:58 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Take a slow moving video of it with cell phone camera or digital camera. Post You tube link attachment as .wmv
Old 11-27-2010, 04:32 PM   #17
Originally Posted by beenthere View Post
Stand back from the boiler. And take a pic so that all or most of the piping is in the pic. And do the same for the piping i n the back of the boiler. There is a specific manor in how the piping must be done.
Take multiple pics if need be. Since I'm not there. i can't walk around the boiler to look at the piping. To see how everything is piped.
Finally got a series of pics that definitely should show what you need. Maybe the pipes were set up wrong.
To see the shots, please go to:
http://picasaweb.google.com/11586085...ssWBVWVBoiler#
colden is offline   Reply With Quote
Old 11-27-2010, 05:09 PM   #18
An old Tradesmen
Rewards Points: 6,112
Ok. You do have a Hartford loop.
Photo 4 shows a main air vent that looks like it doesn't stop venting. That will lose you water if it never stops venting.
Photo 7, looks like those pipes leak when they get cold, do they.
Photo 9. Looks like that 1 pipe has had leaks off and on.
Old 11-27-2010, 10:28 PM   #19
Thanks. I don't have an eye for plumbing.
I have never seen it vent, but it does look like a hunk of rust. What kind or brand of vent do I need? Is there a model number?
I don't know. I haven't seen them leaking, but I never paid attention. I'll make a point to check this out.
What would you recommend? I'm thinking that the suspect joints should be taken apart and reset with teflon tape. Should I replace the main vent or have it eliminated?
Old 11-27-2010, 10:59 PM   #20
An old Tradesmen
Hoffman #75 main vent.
May need to replace some of those fittings. Sometimes its easier to replace them, then clean them up and reuse them.
Tags
wbv/wv peerless
Peerless Steam Boiler, Home use oil fired silvafox HVAC 2 11-09-2010 11:17 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 04:01 PM
Burnham vs Peerless Steam Boilers Jim11 HVAC 1 02-26-2010 11:54 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
